Nach langer, langer Suche. Stunden mit google verbracht und einem Code von
hier habe ich es nun endlich geschafft.
Ich speichere zuerst eine kopie meine Dokuments, lösche dann alle überflüssigen Sheets, und löschen schließlich alle Objecte(=Buttons) aus dem verbliebenen sheet.
Umständlich, aber es funktioniert.
hier der code, falls jemand dasselbe Problem hat:
REM ***** BASIC *****
'Copyright (c) 2011 Frieder Delor, Mailto: Einfach hier im Forum anschreiben :-)
'The funktion: GetPath()is originally from :Copyright (c) 2011 Volker Lenhardt
'This program is free software; you can redistribute it and/or modify it under
'the terms of the GNU General Public License as published by the Free Software
'Foundation; either version 2 of the License, or (at your option) any later
'version.
'This program is distributed in the hope that it will be useful, but WITHOUT
'ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
'FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
'You should have received a copy of the GNU General Public License along with
'this program; if not, write to the Free Software Foundation, Inc., 59 Temple
'Place, Suite 330, Boston, MA 02111-1307 USA
Sub Main
ExportToODS ("Cockpit")
end sub
Sub ExportToODS (sTableNam As String)
sPath = GetPath
If sPath = "" Then
MsgBox "Invalid directory", 16, "ERROR"
goTo Zeile1
End If
Zeile0:
sStandard = "MyCockpit_" & Format(Now,"dd.mm.yyyy")
sName=InputBox ("Please enter a name" & Chr(10) & _
"for the file" , "ODS Name", sStandard )
If sName="" Then
nVar=MsgBox ("You didn't enter a name. " & Chr(10) & _
"Please specify the name. " & Chr(10) & _
"If you click on 'CANCEL' " & Chr(10) & _
"the export will be aborted.", 1, "ERROR")
If nVar=1 then 'OK clicked
goTo Zeile0
Else
goTo Zeile1
End if
End if
sFileName= sName & ".ods"
If FileExists(sPath & sFileName) then
nVar=MsgBox ("The file exists already. " & Chr(10) & _
"Do you want to replace the document? " & Chr(10) & _
Chr(10) & _
"'CANCEL' = abort export " & Chr(10) & _
"'NO' = reenter name" & Chr(10) _
, 3, "Fehler")
Select Case nVar
Case 2 'Cancel clicked
goTo Zeile1
Case 6 'Yes clicked
Case 7 'No clicked
goTo Zeile0
End Select
end if
ThisComponent.addActionLock
ThisComponent.LockControllers
oDoc = ThisComponent
oSheets = oDoc.Sheets
oSheet1 =oDoc.Sheets.getByName(sTableNam)
Delete_PrintAreas
For n = 0 To oSheets.getCount - 1
oSheet=oDoc.Sheets(n)
if oSheet.Name= sTableNam Then
lEndCol= GetLastUsedColumn(oSheet1)
lEndRow=GetLastUsedRow(oSheet1)
Set_PrintAreas (n ,0 ,0 ,lEndCol ,lEndRow)
End if
Next
export_cockpit(sPath & sFileName)
Delete_PrintAreas
adjustDocument (sPath & sFileName)
MsgBox "Cockpit successfully exported at" & CHR$(10) & ConvertFromUrl(sPath & sFileName) , 0, "Success"
Zeile1:
ThisComponent.UnlockControllers
ThisComponent.removeActionLock
End sub
sub Delete_PrintAreas 'Alle Druckbereich Löschen
oSheet = oDoc.Sheets(0)
for n =0 to oDoc.Sheets.getCount - 1
oDoc.Sheets(n).setPrintAreas(Array ())
Next
end sub
Sub Set_PrintAreas (nSheet As Integer,lStartCol As Long,_
lStartRow As Long,lEndCol As Long,lEndRow As Long) 'Drukbereich festlegen
Dim CellRangeAddress As New com.sun.star.table.CellRangeAddress
oSheet = oDoc.Sheets(nSheet)
CellRangeAddress.Sheet = nSheet
CellRangeAddress.StartColumn = lStartCol
CellRangeAddress.StartRow = lStartRow
CellRangeAddress.EndColumn = lEndCol
CellRangeAddress.EndRow = lEndRow
aPrintAreas()=Array (CellRangeAddress)
oSheet.setPrintAreas(aPrintAreas())
End sub
Function GetLastUsedRow(oSheet as Object) As Integer
Dim oCell
Dim oCursor
Dim aAddress
oCell = oSheet.getCellByPosition(0, 0)
oCursor = oSheet.createCursorByRange(oCell)
oCursor.gotoEndOfUsedArea(True)
aAddress = oCursor.RangeAddress
GetLastUsedRow = aAddress.EndRow
End Function
' Returns the number of the last column
'of a continuous data range in a sheet.
Function GetLastUsedColumn(oSheet as Object) As Long
Dim oCell
Dim oCursor
Dim aAddress
GetLastUsedColumn = aAddress.EndColumn
End Function
Function GetPath() As String
Dim oPathSettings, oFolderDialog
Dim sPath As String
oPathSettings = CreateUnoService("com.sun.star.util.PathSettings")
sPath = oPathSettings.Work
oFolderDialog = _
CreateUnoService("com.sun.star.ui.dialogs.FolderPicker")
oFolderDialog.SetDisplayDirectory(sPath)
If oFolderDialog.Execute() = _
com.sun.star.ui.dialogs.ExecutableDialogResults.OK Then
sPath = oFolderDialog.GetDirectory
Else
GetPath = ""
Exit Function
End If
If Right(sPath, 1) <> "/" Then sPath = sPath & "/"
GetPath = sPath
End Function
sub export_cockpit (sFileName AS String)
dim args1(1) as new com.sun.star.beans.PropertyValue
args1(0).Name = "ExportFormFields" 'just show the contents of the Form.Fields
args1(0).Value= True
args1(1).Name = "Printing" ' you don't need that.
args1(1).Value= 0
dim args2(2) as new com.sun.star.beans.PropertyValue
args2(0).Name = "FilterName"
args2(0).Value = ""
args2(1).Name = "FilterData"
args2(1).Value = args1
args2(2).Name = "SelectionOnly" 'Only the selected printarea will get exported
args2(2).Value = true
ThisComponent.storeToURL(sFileName,args2())
end sub
Sub adjustDocument (documentPath as String)
Dim oDocument
Dim myFileProp(0) as New com.sun.star.beans.PropertyValue
myFileProp(0).name= "Hidden"
myFileProp(0).value= True
oDocument = StarDesktop.loadComponentFromURL(documentPath, "_blank", 0, myFileProp() )
oDocument.Sheets(0).unprotect( Functions.getPassword() )
'Input sheet isn't needed
oDocument.Sheets.removeByName("Input")
' Remove Buttons
Call deleteObjects(oDocument)
' This field is marked es not protected (for further information have a look @ Function.protectSheet
DIM budgetProtection
budgetProtection = oDocument.Sheets(0).getCellRangeByName("B4").CellProtection
budgetProtection.isLocked = TRUE
oDocument.Sheets(0).getCellRangeByName("B4").CellProtection = budgetProtection
oDocument.Sheets(0).protect( Functions.getPassword() )
'Save changes
oDocument.store()
'Close document
oDocument.close(false)
end sub
Sub deleteObjects(oDocument as Object)
Dim nextInputRow as Integer
Dim CellRange
nextInputRow = 21 ' Row, where the opps will appear in the cockpit sheet. All Buttons are above of this area
' Normally the input in the cockpitsheet should start @ row 21
IF(oDocument.Sheets(0).getCellRangeByName("A" & nextInputRow - 1).String <> "RM Flag") THEN
' If the keyword "RM Flag" is not @ "A21" --> search for it
nextInputRow = 0
DO
nextInputRow = nextInputRow + 1
LOOP UNTIL oDocument.Sheets(0).getCellRangeByName("A" & nextInputRow).String = "RM Flag"
nextInputRow = nextInputRow + 1 ' Jump to the next free row
END IF
CellRange = oDocument.Sheets(0).getCellRangeByName("A1:N" & nextInputRow)
Flags = com.sun.star.sheet.CellFlags.OBJECTS ' remove (only) Objects (Buttons are Objects)
CellRange.clearContents(Flags)
END SUB
*viel Spaß beim scrollen
PS: der einzige Schönheitsfehler ist jetzt noch, dass das exportierte Sheet alle Makros enthält --> ich werde beim öffnen gefragt, ob ich makros erlauben will. Kann man das irgendwie umgehen, indem man alle Makros aus dem dokument löscht?
