PDF Export einzelne Seite
Jörg
Re: PDF Export einzelne Seite
Beitrag von Jörg »
Guck mal im Forum unter
viewtopic.php?f=18&t=7619#p29102
Hatte mir gut geholfen.
Gruß Jörg
Gruß Jörg
Win 10 Pro AOO 4.1.15
Jörg
Beitrag von Jörg »
Hallo nochmal,
vieleicht auch das:
sub PDFspeichern
sTabName = Thiscomponent.currentcontroller.activesheet.name
msgbox sTabName
rem define variables
dim document   as object
dim dispatcher as object
document   = ThisComponent.CurrentController.Frame
dim args1(2) as new com.sun.star.beans.PropertyValue
args1(0).Name = "URL"
args1(0).Value = "file:///E:/openoffice/Monatsabrechnungen/2014/" & sTabName & ".pdf"
args1(1).Name = "FilterName"
args1(1).Value = "calc_pdf_Export"
args1(2).Name = "FilterData"
args1(2).Value = Array(Array("UseLosslessCompression",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Quality",0,90,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ReduceImageResolution",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("MaxImageResolution",0,300,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("UseTaggedPDF",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SelectPdfVersion",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportNotes",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportBookmarks",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("OpenBookmarkLevels",0,-1,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("UseTransitionEffects",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("IsSkipEmptyPages",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("IsAddStream",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("EmbedStandardFonts",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("FormsType",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportFormFields",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("AllowDuplicateFieldNames",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("HideViewerToolbar",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("HideViewerMenubar",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("HideViewerWindowControls",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ResizeWindowToInitialPage",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("CenterWindow",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("OpenInFullScreenMode",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("DisplayPDFDocumentTitle",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("InitialView",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Magnification",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Zoom",0,100,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("PageLayout",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("FirstPageOnLeft",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("InitialPage",0,1,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Printing",0,2,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Changes",0,4,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("EnableCopyingOfContent",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("EnableTextAccessForAccessibilityTools",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportLinksRelativeFsys",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("PDFViewSelection",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ConvertOOoTargetToPDFTarget",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportBookmarksToPDFDestination",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("_OkButtonString",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("EncryptFile",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("PreparedPasswords",0,,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("RestrictPermissions",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("PreparedPermissionPassword",0,Array(),com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Selection",0,,com.sun.star.beans.PropertyState.DIRECT_VALUE))
dispatcher.executeDispatch(document, ".uno:ExportToPDF", "", 0, args1())
dim args4(0) as new com.sun.star.beans.PropertyValue
args4(0).Name = "ToPoint"
args4(0).Value = "$A$3:$P$160"
dispatcher.executeDispatch(document, ".uno:GoToCell", "", 0, args4())
dispatcher.executeDispatch(document, ".uno:ClearContents", "", 0, Array())
rem------------------------------------------------------------------
dim args9(0) as new com.sun.star.beans.PropertyValue
args9(0).Name = "ToPoint"
args9(0).Value = "$A$3"
dispatcher.executeDispatch(document, ".uno:GoToCell", "", 0, args9())
rem------------------------------------------------------------------------
osheet = thiscomponent.currentcontroller.activeSheet
     sNewName = inputbox("Bitte neuen Blattnamen eingeben","Monatswechsel","Neuer Abrechnungsmonat")
     osheet.name = sNewName
Gruß Jörg
Jörg
Beitrag von Jörg »
was mir noch eingefallen ist:
Wenn nicht schon passiert, event. noch den Druckbereich festlegen.
Gruß Jörg
Gruß Jörg
so sollte es funktionieren:
Sub S_Export_current_active_Sheet_as_PDF_file
    Dim myProps(0) as New com.sun.star.beans.PropertyValue
    oSheet = Thiscomponent.currentController.activeSheet
    sTabname = oSheet.name
    osheets = ThisComponent.Sheets
    dim APrintareas(osheets.count - 1)
    'Druckbereiche löschen
    for i = 0 to osheets.count - 1
            APrintareas(i) = osheets(i).printareas
            if osheet.RangeAddress.Sheet <> i then
                osheets(i).setprintAreas(Array())
            endif
    next i
    sURL = Left (ThisComponent.Url, Len(ThisComponent.Url) - 4)+"_"+sTabname+".pdf"
    'export PDF
    myProps(0).Name="FilterName"
    myProps(0).Value = "calc_pdf_Export"
    ThisComponent.storetoUrl(sURL,myProps())
    'Druckbereiche wieder setzen
        osheets(i).setprintAreas(APrintareas(i))
    next i
    Thiscomponent.store
    msgbox ("Das Tabellenblatt "+sTabname+" wurde erfolgreich in den Quellordner exportiert",64,"aktuelles Tabellenblatt als .pdf exportieren")
TrueColor
Beitrag von TrueColor »
Huutsch hat geschrieben:In meinem Fall verschiebe ich die Images, mit denen ich die Makros auf der Seite starte, aus dem Duckbereich, weil ich sie nur für die Bedienung möchte, nicht aber auf dem Papier.
Wenn der Druckbereich gelöscht ist, dann erscheinen sie trotzdem auf dem Papier, weil OO dann alles druckt, was nicht leer ist.
Ich gehe mal davon aus, du nutzt die Grafischen Schaltflächen aus den Formular-Steuerelementen (unter "weitere Steuerelemente"). Die Steuerelemente haben alle eine Eigenschaft "druckbar". Kannst du über das Kontextmenü > Kontrollfeld... > Allgemein editieren. Dann werden sie nicht mehr mitgedruckt.
System:
LibO 6 + LibO 7
