REM ***** BASIC *****
Option Explicit
Sub DelSome()
dim oSheet as object
dim oCellCursor as object
dim nRow as long
dim i as Long
oSheet = ThisComponent.CurrentController.ActiveSheet
oCellCursor = oSheet.createCursor
oCellCursor.GotoEndOfUsedArea(False)
nRow = oCellCursor.getRangeAddress().endRow
for i = nRow to 0 Step -1
if oSheet.getCellByPosition(1,i).String <> "Insgesamt" then oSheet.getRows.removeByIndex(i,1)
next
Option Explicit
Sub DelSome2()
dim nRow as long
dim i as Long
nRow = getLastCell(oSheet).endRow
select case lcase(oSheet.getCellByPosition(2,i).String)
case "männlich"
oSheet.getCellByPosition(0,i+1).Value = oSheet.getCellByPosition(0,i).Value
oSheet.getCellByPosition(1,i+1).String = oSheet.getCellByPosition(1,i).String
case "insgesamt"
' nix zu tun
case else
end select
next
Function getLastCell(Optional oStartSheet as object) as object
if isMissing(oStartSheet) Then
else
oSheet = oStartSheet
endif
getLastCell = oCellCursor.getRangeAddress()
End Function
Option Explicit
Sub DelSome3()
dim nRow as long
dim i as Long
case "unter 3 jahre"
oSheet.getCellByPosition(0,i+1).String = oSheet.getCellByPosition(0,i).String
case "insgesamt"
' nix zu tun
case else
end select
next
else
endif
End Function
