[gelöst] Wie funktioniert _mouseReleased ?
Jonny1
Beitrag von Jonny1 »
Folgende Makros habe ich geschrieben:
REM  *****  BASIC  *****
'Option Explicit
Global oDocView As Object
Global oMouseClickHandler As Object
Global Anzahl as string, AnzahlAlt as String
Sub RegisterMouseClickHandler
  oDocView = ThisComponent.currentController
  oMouseClickHandler = _
  createUnoListener("MyApp_", "com.sun.star.awt.XMouseClickHandler")
'  writedbginfo oMouseClickHandler
  oDocView.addMouseClickHandler(oMouseClickHandler)
Sub UnregisterMouseClickHandler
  on error resume next
  oDocView.removeMouseClickHandler(oMouseClickHandler)
  on error goto 0
sub CheckBox1
	Dim LightRed as Long, Green5 as Long, a as Boolean, b as String, c as String, d as Long
	LightRed = 16711680
	Green5 = 44544
	a = ThisComponent.DrawPage.Forms.getByIndex(0).GetByName("Check Box 1").State
	if a then
		b = "registered"
		c = "Click here to unregister the page."
		d = Green5
	else
		b = "unregistered"
		c = "Click here to register the page."
		d = LightRed
	end if
	ThisComponent.DrawPage.Forms.getByIndex(0).GetByName("Check Box 1").Label = b
	ThisComponent.DrawPage.Forms.getByIndex(0).GetByName("Check Box 1").helptext = c
	ThisComponent.DrawPage.Forms.getByIndex(0).GetByName("Check Box 1").backgroundcolor = d
end sub
Sub MyApp_disposing(oEvt)
Function MyApp_mousePressed(oEvt) As Boolean
  MyApp_mousePressed = False
End Function
Function MyApp_mouseReleased(oEvt) As Boolean
	Dim Anzahl
	Anzahl = oEvt.ClickCount
	ThisComponent.DrawPage.Forms.getByIndex(0).GetByName("LabelAnzahl").Label = "ClickCount = " & Anzahl
	if Anzahl = 2 then mSubForDoubleClick
	if Anzahl = 1 then mSubForSingleClick
	MyApp_mouseReleased = False
End Function
sub mSubForSingleClick
	print "mSubForSingleClick"
end sub
sub mSubForDoubleClick
	print "mSubForDoubleClick"
end sub
Nur wenn ich "if Anzahl = 1 then mSubForSingleClick" lahm lege, kommt die eine Zeile davor geschriebene Bedingung "if Anzahl = 2" zum Tragen.
Warum?
Meine Vermutung ist es, daß die Funktion MyApp_mouseReleased(oEvt) bei Doppelcklick zweimal durchlaufen wird. Ich vermute, daß beim ersten Durchlauf „Anzahl“ den Wert 1 zugewiesen bekommt und, wenn "if Anzahl = 1 then mSubForSingleClick" vorhanden ist und mSubForSingleClick auferufen wird, die widerstpensige Maus nach sehr kurzem Warten keine Lust mehr verspürt, das Event nochmals auszulösen.
Habe ich richtig geraten oder sind es Hirngespinste?
Mit eigenwilligen Mäusen kenne ich mich nicht gut aus.
Wie kann ich der Anweisung "if Anzahl = 1 then mSubForSingleClick" mitteilen, daß sie ein wenig – wie lange? - warten soll, damit das Mäuschen eventuell das Event ein zweites mal auslöst und mich nicht im Stich läßt?
Zuletzt geändert von Jonny1 am Do, 24.01.2013 21:08, insgesamt 1-mal geändert.
Re: Wie funktioniert _mouseReleased ?
Beitrag von balu »
Hallo Jonny1,
na ich weiß nicht so recht ob das gut geht, eine IF...THEN-Anweisung ohne ELSE beziehungsweise ohne END IF? Und das ganze gleich 2 mal
Online Hilfe(F1) hat geschrieben: Trifft OpenOffice.org Basic auf eine If-Anweisung, so wird zunächst die Erfüllung der Bedingung geprüft. Ist die Bedingung erfüllt (True), so werden alle nachfolgenden Anweisungen bis zur nächsten Else- oder ElseIf-Anweisung ausgeführt.
Verstehst Du das, oder muss ich das für dich genauer erklären?
Jonny1
Die Prozedur:
sub Probe
	a=0
	if a=0 then exit sub
	print "balu ist ein sehr schlauer Kerl"
end sub
funktionert einwandfrei auch ohne ELSE und END IF und weigert sich zu verkünden: „balu ist ein sehr schlauer Kerl“.
Dennoch habe ich in das Makro ENDIF eingefügt, um das Restrisiko zu beseitigen. NICHTS hat sich geändert.
Dann habe ich sinnloserweise auch ELSE eingefügt. Und auch da hat sich selbstverständlich NICHTS geändert.
Wie sollte es auch?
Das Problem ist nicht, daß alle nachfolgende Anweisungen bis auf ELSE und/oder ENDIF ausgeführt werden!
Das Problem ist - wie von Anfang an sehr deutlich geschrieben - daß die allererste Abfragung "if Anzahl = 2" als nicht zutreffend beurteilt wird, obwohl ich doppelt geklickt habe. Das ist das Problem.
Also, noch einmal:
"if Anzahl = 2" wird als FALSCH bewertet.
Die nachfolgende Abfragung:
"if Anzahl = 1" wird als WAHR bewertet.
Ich habe unzählige male doppelt geklickt und jedes mal reagierte das Makro so, als hätte ich nur einmal geklickt.
Sind die zwei Abfragungen nicht da, dann schreibt das Makro ganz korrekt die richtige Anzahl der Klicks - ob sie nun 1, 2, 3, 4, 5 oder mehr sind, mit der Anweisung:
"ThisComponent.DrawPage.Forms.getByIndex(0).GetByName("LabelAnzahl").Label = "ClickCount = " & Anzahl"
Offensichtlich ist nicht das Unterlassen von ENDIF und schon gar nicht das Unterlassen von ELSE das Problem.
Ich vermute, daß der erste Klick schon das Durchlaufen von MyApp_mouseReleased(oEvt) veranlasst. Ohne Abfragung wird - nehme ich an - MyApp_mouseReleased(oEvt) wieder durchlaufen und jedes mal wird die korrekte Anzahl der bisherigen Klicks in das Label für jeden sichtbar geschrieben.
Hat sich aber der Verlauf in einer längeren Prozedur verfangen, dann - vermute ich - wird MyApp_mouseReleased(oEvt) nicht mehr durchlaufen, ganz egal wie oft ich noch klicke.
Das Problem ist doch daß deine Funktion schon beim ersten Klick aufgerufen wird →einen klick zählt und deshalb 'subSingleclick' aufruft.
Du kannst nur dafür sorgen das die Funktion beim ersten Klick nur False zurückgibt, um dann die Chance zu haben den 2. Klick zu registrieren.
Etwa so:
       Dim Anzahl
       if Anzahl = 1 then
       end if
       if Anzahl = 2 then
       mSubForDoubleClick
       end if
    End Function
Damit erfolgt bei Einfachklicks "keine" Reaktion.
Zuletzt geändert von Karolus am Do, 24.01.2013 08:16, insgesamt 1-mal geändert.
Beitrag von balu »
@Jonny1
   Dim  Anzahl
Am Makroanfang und in der Function deklarierst Du die Variable Anzahl unterschiedlich. Einmal als String und einmal als Variant. Wäre es nicht besser wenn Du das noch mal überarbeitest?
Dannenhöfer hat geschrieben: Globale Variablen werden ebenfalls im Kopfbereich eines Moduls deklariert, sie haben auch nach beenden des Moduls Gültigkeit.
Und auf Grund dessen kann es wohl zu komplikationen kommen. Die Variablen deklaration sollte schon eindeutig sein, denn sonst kann es später zu noch größeren Problemen kommen. Und ja! Mir ist das auch schon passiert.
Wo hast Du diese Änderungen vorgenommen?
Generelle Fragen.
Sehe ich das richtig, das Du mit der CheckBox einen Zähler konstruieren willst?
Oder willst Du nur den doppelklick abfangen?
@Karolus
Du hast in deinem Code ein END IF vergessen. Denn wenn ich deine Function gegen die von Jonny1 tausche, kommt es zu der Fehlermeldung:
"Sub innerhalb einer Prozedur unzulässig"
Setze ich aber END IF an die richtige Stelle, läufts dann auch. Das nur zur Info.
Jonny1
Den Fehler habe ich gefunden und hier eine funktionierende Version geschrieben:
Global Anzahl as long
  on error goto 0
sub CheckBox1
	LightRed = 16711680
	Green5 = 44544
	if a then
		b = "registered"
		d = Green5
	else
		b = "unregistered"
		d = LightRed
	end if
end sub
End Function
	if Anzahl = 1 then VerteilerSub
End Function
sub VerteilerSub
	dim ZeitGewartet as long
	ZeitGewartet = 0
Sprung1:
	wait(300)
	ZeitGewartet = ZeitGewartet + 300
	select case Anzahl
		case 1
			mSubForSingleClick
		case 2
			if ZeitGewartet = 300 then goto Sprung1
			mSubForDoubleClick
		case 3
			if ZeitGewartet < 900 then goto Sprung1
			mSubFuerDreifachesKlicken
		case 4
			if ZeitGewartet < 1200 then goto Sprung1
			mSubFuerVierfachesKlicken
		case 5
			if ZeitGewartet < 1500 then goto Sprung1
			mSubFuerFuenffachesKlicken
		case 6
			if ZeitGewartet < 1800 then goto Sprung1
			mSubFuerSechsfachesKlicken
		case 7
			if ZeitGewartet < 2100 then goto Sprung1
			mSubFuerSiebenfachesKlicken
		case is > 7
			if ZeitGewartet < 2400 then goto Sprung1
			mSubFuerAchtUndMehrfachesKlicken
	end select
end sub
end sub
end sub
sub mSubFuerDreifachesKlicken
	print "mSubFuerDreifachesKlicken"
end sub
sub mSubFuerVierfachesKlicken
	print "mSubFuerVierfachesKlicken"
end sub
sub mSubFuerFuenffachesKlicken
	print "mSubFuerFuenffachesKlicken"
end sub
sub mSubFuerSechsfachesKlicken
	print "mSubFuerSechsfachesKlicken"
end sub
sub mSubFuerSiebenfachesKlicken
	print "mSubFuerSiebenfachesKlicken"
end sub
sub	mSubFuerAchtUndMehrfachesKlicken
	print "mSubFuerAchtUndMehrfachesKlicken"
end sub
Vielen Dank für deine Hilfe, Karolus.
Wenn du aber schreibst:
muss ich widersprechen, weil keines meiner Makros die Funktion aufruft, geschweige denn auswertet. Es sind die verborgenen Programmteile - damit meine ich die Programmteile, welche die Hersteller des BASIC-Interpreters geschrieben haben - welche die Funktion "MyApp_mouseReleased(oEvt)" aufrufen. Die Zuweisung:
kam zwar auch in meiner Version vor, aber nur deswegen, weil ich sie in einem Beispiel von einem anderen Programmierer gefunden hatte und damals nicht wusste, ob die verborgenen Programmteile sie benötigten oder nicht. Ich habe mir gedacht, daß es nicht so schädlich seine konnte, sie da zu belassen.
Die Anfrage: "if Anzahl = 1" ist auch deswegen zwecklos, weil die Zuweisung
ohnehin am Ende der Sub in deiner Version durchgeführt wird.
Nein.
Die Lösung besteht darin, eine Verteiler-Prozedur schon dann aufrufen zu lassen, wenn die verborgenen Programmteile MyApp_mouseReleased das allerersten mal aufrufen.
Rufen die verborgenen Programmteile MyApp_mouseReleased später ein zweites, drittes, ... hundertfaches mal, dann wird keine meiner sichtbaren Prozeduren mehr durch MyApp_mouseReleased aufgerufen. Diese Funktion beschränkt sich dann darauf, die globale Variable Anzahl nach oben zu verändern.
Meine Verteilerprozedur ist es dann, welche Anzahl wiederholt abliest, eventuell ein wenig wartet, dann sie wieder abliest, bis sie sicher ist, dass sie durch MyApp_mouseReleased nicht mehr verändert wird. Dann ruft VerteilerSub die ausfühjrende Prozedur ab, die dem endgültigen Wert von Anzahl entspricht.
In meinem Beispiel habe ich mich auf ein Maximum von siebenfachem Klicken beschränkt, aber könnte auch viel mehr. Einmal habe ich sogar ein 170-faches Klicken bewirkt. Werte natürlich, die in der Praxis kaum von Nutzen sein dürften, die mir aber geholfen haben, die Arbeitsweise der verborgenen Programmteile zu verstehen.
An Balu:
Vielen Dank auch dir, Balu, für deine Hilfe. An der Adresse viewtopic.php?f=18&t=60995 wirst du dich hoffentlich überzeugen können, daß die Hersteller von BASIC für OO sich die Mühe gemacht haben, den Benutzern zu erlauben, ENDIF wegzulassen (ELSE ohnehin), wenn die Ausführung in derselben Zeile der Abfragung geschieht. Heute habe ich gelernt, daß man ohne ENDIF sogar mehrere Anweisungen durchführen kann, wenn man sie durch einen Doppelpunkt trennt und damit man alle in die Zeile der Abfragung stopft. Eine absolut korrekte Verfahrensweise.
Zu deiner Frage:
Ja. Für dich wäre es besser gewesen, wenn ich penibler gearbeitet hätte. Für mich wäre es schlechter gewesen, weil mir das Zeit gekostet hätte, die ich nicht zur Verfügung hatte. Es war ohnehin absolut klar, dass es für die Ausführung meiner Makros vollkommen irrelevant war, da damals Anzahl nur durch MyApp_mouseReleased(oEvt) gesetzt und abgefragt wurde und dort war es zwar nicht sehr elegant aber praktisch vollkommen egal, wenn Anzahl auch global deklariert wurde. In der neuen Version wird Anzahl nur als globale Variable definiert und damit ist nicht nur die praktische Wirkung, sondern auch die peniblere Betrachtungsweise befriedigt.
Zu deiner Frage:
In den Versuchen, die ich deinetwegen gemacht habe, obwohl ich von deren Überflüssigkeit überzeugt war.
Zu der Frage:
Ich wollte ursprünglich eine Art Transkriptions-Programm schreiben. Man kann Schreibmarken der Art 01h23m51s oder #01:23:51-7# schreiben. Dann klickt man einfach oder doppelt auf die Zeitmarke und ruft man damit VLC an der durch die Zeitmarke angegebenen Stelle ab.
Dadurch, daß man die Wahl zwischen einfachem, doppeltem, dreifachen, etc. Klick hat, hat man auch die Möglichkeit, dem Benutzer die Wahl anzubieten, ob er das Video bis zur nächsten Zeitmarke, bis zum Ende, mit einer kurzen, mittleren oder langen Rückspülung, etc. abspielen will. Es gibt unendliche Möglichkeiten.
Das Transkriptionsprogramm ist seinerseits ein Mittel, um Sozialpsychologische Probleme wie Schimmelpilzwahn, Meldewahn, Zwangsschulwahn, Reptiloidenwahn, etc. zu behandeln.
Wollt ihr mitmachen?
Re: [gelöst] Wie funktioniert _mouseReleased ?
Nö! :shock:
Beitrag von balu »
Hallo Jonny1,
Kannst ruhig sagen das Du das von Andrew Pitonyak hast.
Da muss ich dich doch Fragen: Weisst Du was da geschieht? Ist dir die Funktion des Doppelpunktes wirklich eindeutig bewusst?
Ich habe jetzt irgendwie das Gefühl das Du das für dich gar nicht richtig hinterfragst.
Jonny1 hat geschrieben: Zu deiner Frage:
Ich wollte dich nur auf etwas aufmerksam machen was durchaus einmal zu komplikationen führen kann, wenn man auf solche kleinigkeiten nicht achtet. Und grad die deklaration von Variablen ist ein nicht zu verachtender Stolperstein den man schnell übersehen kann, wenn man auf einer Fehlersuche oder ähnlichem ist.
Ist dir der Einsatz von Global deklarierten Variablen bewusst, und weisst Du auch was das für Konsequenzen mit sich führen kann?
Kenn ich net, und sagt mir nix.
Njet.
