VBA in Libre Office Basic umschreiben
TorbenIT
Beitrag von TorbenIT »
Hallo Leute,
ich bin gerade dabei meinen VBA Code in Libre office code umzuschreiben - könnte da jemand mir behilflich sein?
 Sheets("Matrix").Select
    Range("C3").Select
    ActiveCell.FormulaR1C1 = _
        "=SUMIF(Aufstellung!R13C2:R[997]C,Matrix!RC[-1],Aufstellung!R13C3:R[997]C)"
    Range("C3").Select
    Selection.AutoFill Destination:=Range("C3:C42"), Type:=xlFillDefault
    Range("C3:C42").Select
    ActiveWindow.ScrollRow = 9
    ActiveWindow.ScrollRow = 8
    ActiveWindow.ScrollRow = 7
    ActiveWindow.ScrollRow = 6
    ActiveWindow.ScrollRow = 5
    ActiveWindow.ScrollRow = 4
    ActiveWindow.ScrollRow = 3
    ActiveWindow.ScrollRow = 2
    ActiveWindow.ScrollRow = 1
    Range("D3").Select
        "=SUMIF(Aufstellung!R13C2:R[997]C,Matrix!RC[-2],Aufstellung!R13C4:R[997]C)"
    Range("D3").Select
    Selection.AutoFill Destination:=Range("D3:D42"), Type:=xlFillDefault
    Range("D3:D42").Select
    Range("B3:D42").Select
    Selection.Copy
    Range("F3:H42").Select
    Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
        :=False, Transpose:=False
    Range("I3:I42").Select
    Application.CutCopyMode = False
    ActiveWorkbook.Worksheets("Matrix").Sort.SortFields.Clear
    ActiveWorkbook.Worksheets("Matrix").Sort.SortFields.Add Key:=Range("I3"), _
        SortOn:=xlSortOnValues, Order:=xlDescending, DataOption:=xlSortNormal
    With ActiveWorkbook.Worksheets("Matrix").Sort
        .SetRange Range("F3:I42")
        .Header = xlNo
        .MatchCase = False
        .Orientation = xlTopToBottom
        .SortMethod = xlPinYin
        .Apply
    End With
    Range("F3:I42").Select
    Selection.Copy
    Sheets("Kassenblatt").Select
    Range("C6:F45").Select
    Range("B6").Select
    ActiveCell.FormulaR1C1 = "=IF(RC[4]>0,R[-1]C+1,"""")"
    Range("B6").Select
    Selection.AutoFill Destination:=Range("B6:B45"), Type:=xlFillDefault
    Range("B6:B45").Select
    ActiveWindow.ScrollRow = 14
    ActiveWindow.ScrollRow = 13
    ActiveWindow.ScrollRow = 12
    ActiveWindow.ScrollRow = 11
    ActiveWindow.ScrollRow = 10
    Range("A6").Select
    ActiveCell.FormulaR1C1 = "=IF(RC[5]>0,R1C4,"""")"
    Range("A6").Select
    Selection.AutoFill Destination:=Range("A6:A45"), Type:=xlFillDefault
    Range("A6:A45").Select
    ActiveWindow.ScrollRow = 15
    Range("I5").Select
mikeleb
Re: VBA in Libre Office Basic umschreiben
Beitrag von mikeleb »
wie weit bist du denn mit dem Umschreiben?
Eine 1-zu-1-Übersetzung ist in der regel nicht möglich oder sinnvoll. Was soll dein Makro leisten?
mikeleb
